Haiku Haiku & HaikuHelper CHANGELOG
Status
Not open for further replies.
Haiku 3.89
- Push notification service improvements
- More accurate timeouts for trouble reporting/notifications
- Cameras removed from Extended Setup will now also be removed from Haiku's configuration
HaikuHelper 2.90
- Switched to a new, faster push API
- Zone Tripped notifications will no longer be sent for Entry/Exit zones
- Cameras removed from Extended Setup will now also be removed from HaikuHelper's configuration
- Minor Default Interface updates
- Internal improvements
- Fixed a few minor bugs with e-mail notifications
- Improved connection handling for Web Interface
- Workaround bug in Ruby HTTP gems to allow connectivity with Ruby/SiriProxy
- jQuery Framework: Default autoglue() map now uses # (id) references instead of . (class) references
- jQuery Framework: $.haiku.unglue() now accepts an optional container argument
- API: OIDs (object IDs) are again returned as MD5 hashes
- API: added Controller.sendUPBLinkOn(), Controller.sendUPBLinkOff(), Controller.sendUPBLinkSet()
- API: Added Controller.stopScript(), Controller.reloadScript()
- API: added onUnitStateChange() event
- Updated documentation
HaikuHelper 2.91
- Switched to SSL for push notifications
- Improved communications with notification server
- Fixed a bug that caused Zone Status notifications to be sent even if they are turned off
- Improved Zone Status notification accuracy
- API: added Zone.isEntry property
Haiku 3.92
- Auxiliary sensors no longer show not ready notice in statusbar
- Fixed bug with lumina mode changes being incorrect
- Fixed unnamed zones/messages to not be listed in statusbar display
- Fixed logging of access granted/denied events for access controls
HaikuHelper 2.92
Haiku 3.93
- Improved weather data reliability
- Fixed a rare crash caused by weather data being invalid
- Tweaks to improve TTS reliability
HaikuHelper 4.0
- Skipped version 3 to synchronize with Haiku 4.0
- 64-bit processor required
- OS X 10.8 or later required
- Fixed issue with timers not firing sometimes/being slow to fire (causing delays in UI updates)
- Fixed extended setup rooms/cameras not being removed if all are removed from controller
- Added support for Ext Setup controller name
- Improved SMTP support
- Added option to send HTML email messages
- Modernized internals
- Switched to modern Objective-C runtime
- Scripting API: Added Controller.longName
- Scripting API: Added Controller.refreshConfiguration()
- Scripting API: Removed: Controller.invalidateObjectCache()
- Scripting API: Removed: Controller.refreshAccessControlReaders()
- Scripting API: Removed: Controller.refreshAreas()
- Scripting API: Removed: Controller.refreshAudioSources()
- Scripting API: Removed: Controller.refreshAudioZones()
- Scripting API: Removed: Controller.refreshAuxiliarySensors()
- Scripting API: Removed: Controller.refreshButtons()
- Scripting API: Removed: Controller.refreshCodes()
- Scripting API: Removed: Controller.refreshMessages()
- Scripting API: Removed: Controller.refreshThermostats()
- Scripting API: Removed: Controller.refreshUnits()
- Scripting API: Removed: Controller.refreshZones()
- Scripting API: Removed: Controller.refreshExtendedSetup()
I've downloaded 4.0 and I have an invalid configuration error. I can't delete the config and when I add a new config, it's invalid also. Is there a file/pref that I can delete or this the problem that is fixed in 4.01?
Thx,
Richard
Status
