Haiku Haiku & HaikuHelper CHANGELOG
Status
Not open for further replies.
HaikuHelper 2.71
- New, improved script editor
- Added new example theme for Default Interface (Black)
- Interfaces are now always read from the bundled interfaces first, then if not found there, from the user-installed Interfaces folder
- 64-bit only
- Fixes missing lock options in Default interface
- Fixes a potential crash when a controller command fails
Haiku 3.81
- Added Settings option to set a default security code to avoid being prompted for it
- Improved proximity detection feature
- Removed operation timed out dialogs
- Fixed settings being reset/warning dialog about database upgrade error appearing when using Pass Code Lock + Proximity Detection feature
- Fixes a potential crash for newly added controllers
- Improved stability
Haiku 3.82
HaikuHelper 2.72
- Fixed bug with multiple controllers interfering with eachother on Web Interfaces
- Fixed bug with empty controller script not being saved/applied/crash on start up
- Improved Events tab performance on Default Interface
- API: Added onUnitLevelChange() event
- Updated documentation
Haiku 3.83
- The default Security Code is now entered in the Controller Manager > Edit (per controller)
- You will have to re-enter the default security code if you had one set
- Improved handling for security keypad popup in keypad mode
- Fixed date bug with Events log
Haiku 3.84
- Added support for HAI HiFi 2/HAI iPod Dock control and metadata
- Added Trendnet IP672 PTZ support
- Fixed bug in Trendnet IP610 support
HaikuHelper 2.75
- Fixed an issue with unnamed Areas not updating on the Web Interface
- Improved TED 5000 support for TOU/Tiered levels
- Added notifications to Default Interface
- Added support for standard e-mail notifications
- Fixed possibly inaccurate battery level reading on Status tab of Settings window
- Added Helper.speakSound(), Helper.playSound(), Helper.setSpeechStartDelay()
- Added onNotification() event
- Added option to send notifications for zone trips and troubles
- Added onZoneTrip() and onZoneTrouble() events
- Controller.sendEnergyCost() now accepts values 1-4, previously 0-4
- 32-bit support re-enabled
- Fixed a crash related to scripting
Does Apple "roll out" the update availability to different users at various times?  HaikuHelper 2.75 is the newest that my App Store logon can see as of 5:30pm EST.
HaikuHelper 2.80
- New sounds
- Default UI tweaks
- API: Added support for JavaScript confirm()
- API: Added support for delta format for WebSocket notifications (now default in HaikuHelper jQuery Framework)
- API: Object "D" WebSocket notifications no longer include class/number properties
- API: HaikuHelper jQuery Framework now includes option to toggle the new delta format for WebSocket notifications
- API: Added Helper.sendTestNotification()
Haiku 3.87
- Internal improvements
- Improvements to proximity location picker
- Fixed "Controller command failed" error when dimming to 0% on non-HLC lighting
- Fixed TTS bug
Status
