So I have a small thing im doing.
I have an alarm panel. I want 10 LED lights and 8 strobes to go off if the alarm sounds. The alarm itself is a Vista 20P and it can't handle 5amps. All of my devices when added equal about 5.15 amps.
Soo i figured id use an external 12V 5amp power box to do this. Its 120 in and outputs 12V... very standard.
So no issues there... now my issue is wiring in this relay.
I want to wire it in so that my siren output on my alarm panel goes into this relay, which will CLOSE my circuit.
Easy enough to do. I'll wire everything together and give it positive power on the power supply. Then i'll take the negative side, wire it into the relay, and the other side goes to the devices... so that when the relay gets tripped it powers up all my stuff.
Im using an Altronix RB1224 relay.
Anybody know how I wire this? Im sort of stuck. I know im supposed to give it POSITIVE and NEGATIVE constant power, but i really have no idea how im supposed to TRIP it. It has a NC and NO and C on both sides... the side above the NEGATIVE input, well that NC works, but the other side doesnt... sooo any thoughts here on how to wire it? I havnt done relays in a while.
