Keypad one also said communication failed before I installed the 2nd keypad. To my data but I have the red connected to +VKP, Green in Data A, Yellow in Data B and Black into NEG. I connected the matching colors from my keypad. Now on keypad 1, I have the main door sensor connected. The Yellow wire from the sensor is connected to the black on the keypad who is also connected the bloack going to the panel. The Green from the sensor is connected to the Blue from the keypad. I also have the a door sensor that should be going to my 2nd keypad however, I did not connect that yet. Want to get the keypad up and running first.
My first keypad (M1KPB) the termination is on JP2. My 2nd keypad (M1KP3)the termination is on JP1. On my panel the termination is on JP2. I also noticed that a termination of JP2 was installed on the board. I re-read the book and I don't see that JP2 on the board should be used. I think originally I was looking at ELK-M1DBHR graph. If I remove the JP2 from the board can you confirm if all looks good based on my above description please?
