2nd keypad for garage
The "lost comm" goes away right? If the symptom is that it loses comm during the enrollment, that's normal - after enrollment is done it should be fine.
Just to be picky about one issue - the keypads are daisychained (technically). The chain starts at one keypad, has the main PCB in the middle and the second keypad at the other end. This is a daisychained RS485 network.
For correct operation both keypads need to be terminated and the main board needs no termination - which is how you have stated it is set up.
When using a data bus hub, you are still daisychianing the network, its just twice as long.
Good to see it is working for you now.
Mick
All is working nicely. Thanks everybody for your patience with me. I know I started on the wrong foot with all this installation but I did learn a few things here and if it wasn't for this forum I would not have been able to install all. Look forward to add the remaining of my equipment to my set up and I promise to do more reading before asking stupid avoidable questions
