bbruck
Purchased a year ago and never used.
New $104.99 (on sale at Smarthome for $99.95)
Selling for $50 + $5.95 Shipping
(Shipping discount for multiple items)
Overview
Inputs can be used to trigger INSTEON commands
Four opto-isolated inputs for dry-contacts or digital signals
Two digital or analog level inputs
Individual timer settings for each input
Plug-in connection with pass-through outlet
Essential Info
This EZIO6I by SimpleHomeNet allows virtually any sensor connected to one of the six inputs on the interface module to send out a signal or group command to INSTEON devices. You can detect and monitor external events by using a smoke detector to have all the lights in the house flash when triggered, or a temperature sensor to activate your thermostat when the temperature gets too high or too low, the applications are virtually endless. You can create timers that send commands after a pre-set amount of time, from 1 second to 255 minutes, and change the behavior of the inputs relative to INSTEON commands that are sent, the group, number, the order of commands, etc. The interface module is a plug-in device, so you can eliminate long run wiring complications by simply plugging the device in at the closest point to your sensors.
While basic functions can be programmed manually, advanced functionality can be programmed with the EZSrve, central automation controller. If you already have a central automation controller or a software package for your INSTEON network that doesn't have the correct parameters to program the advanced functionality of this device, you can download the free Simplehomenet Utility Suite which works in conjunction with an INSTEON Powerlinc Modem (2412U, 2413U or 2413S). If you need PC-free operation for simple timers, the SHN Utility Suite also interfaces with the INSTEON Powerlinc Controller.
Overview
Essential Info
