bbruck
bought a year ago and never used.
$144.99 on sale for $129.98 at Smarthome
Selling for $65 + $5.95 shipping
Shipping discount if multiple items purchased
Overview
<p class="ProdContainer">
Bridging the gap between home automation and audio video components usually requires the purchase and advanced installation of expensive control system hardware and controllers. The EZUIRT Universal IR/INSTEON Transceiver # 5010H by SimpleHomeNet is an affordable plug-in solution that will allow communication between devices on an INSTEON and/or X10 network with audio video components. The EZUIRT recognizes the codes sent out via IR remote control and translates them into INSTEON commands. This allows you to control INSTEON-compatible devices (lighting, fans, appliances and HVAC) or scenes with the same remote used for your entertainment equipment (Television, CD player, DVD player and stereo). EZUIRT is also an IR sender, which will convert INSTEON and/or X10 commands to IR codes that your A/V equipment can readily understand. With the press of a single button from your INSTEON-compatible device, you can create a scene that will turn on your air conditioner, cable/satellite receiver, television, stereo, fireplace, and dim the lights.
While basic functions can be programmed manually, advanced functionality can be programmed with the EZSrve, central automation controller. If you already have a central automation controller or a software package for your INSTEON network that doesn't have the correct parameters to program the advanced functionality of this device, you can download the free Simplehomenet Utility Suite which works in conjunction with an INSTEON Powerlinc Modem (2412U, 2413U or 2413S). If you need PC-free operation for simple timers, the SHN Utility Suite also interfaces with the INSTEON Powerlinc Controller.
Overview
- Allows an IR remote to control INSTEON
- Use an INSTEON command to control an IR device
- Functions as an IR distribution hub
- LED indicator for code confirmation
- Easy installation
- This device will not send out X10 commands
