I bought this Turtle Beach USB sound card (SPDIF via optical out):
http://www.newegg.com/Product/Product.aspx?Item=N82E16829118007
And paired it with this two port Lantronix USB device server (I ended up with the newer version UB2100002-01 not UB2100001-01):
http://www.newegg.com/Product/Product.aspx?Item=N82E16833995092
Now I have great sounding audio streamed from Premise to my stereo (sounds as good as any PC audio), all over my network I'm also using the second USB port with a PL-2303 serial to USB adapter, giving me a remote serial port too.
The audio works flawlessly (make sure you use the driver files from the Turtle Beach site). It appears I'll be able to add more sound cards. I have another coming to test this theory. However, the control panel the Turtle Beach installs is crap. I installed the full exe, then stole the driver files (from the directory called "Driver"), uninstalled all turtle drivers and installed the sound card's inf manually using the stolen "Driver" folder.
EDIT: Also note that Windows XP will still try to install their 2001 USB Audio Driver, every time you plug/unplug the Turtle Beach Advance Micro II. Be sure to find: wdma_usb.inf and wdma_usb.PNF and change their file extension or delete them. These files are in: %SystemRoot%/inf
The only quirk with the install is you need to write a script to reset the COM port every time SYS reboots (if you use a serial to USB adapter). This has nothing to do with the UBOX 2100 as SYS will do this even if you: plug the USB cable directly into your server, unplug it, and then plug it back in. The soundcard works fine even if you reboot or unplug the UBOX 2100 then plug it back in. However, a couple times it didn't, so run code like this on SYS start up:
evices.ComputerAudio.Detect = true
Lantronix claims the UBOX 2100 can handle video. The UBOX 2100 works very well on my XP Pro machine and I'm wondering if it could support one of the new USB only touchscreens such as the MIMO?
From the Lantronix User Guide:
"USB Speeds and Throughput
The UBox 4100 supports USB low speed and full speed, while the UBox 2100 supports low, full and high speed. The UBox 4100 can sustain, depending on conditions, approximately 5-6 Mb/sec
throughput. The UBox 2100 can sustain, depending on conditions and transaction types, approximately 12-15 Mb/sec.
The UBox 4100 supports most low and full speed devices, including class and vendor specific devices. The UBox 4100 does not support high-speed isochronous devices; it supports isochronous devices for audio only. In addition to these devices, the UBox 2100 supports most high-speed devices, as limited by the overall throughput. The UBox 2100 also supports full speed isochronous video. The UBox 2100 does not support High Speed Isochronous devices."
