Access control reader not reporting status
edselrt
I just noticed that using the request to exit input of the reader, the actual status will not display (lock or unlock?). Is this a known limitation?
The HAI controller does not track the use of the hardware "press to exit" input. There is no firmware update available for this. A contact on the door could be used to monitor when the door is opened, if desired.
