Anyone using Elve here? Need Zwave help
Frunple
Posted this on the Elve board also.
Not using my Omni Pro anymore and am trying to get the Elve Zwave driver going.
In the device properties, for battery level, lock state, and all thermostat entries I get this error:
Error: OverflowException: Arithmetic operation resulted in an overflow.
And this in the log:
Date:     10/29/2017
Time:     5:19:01 PM
Severity: Error
Source:   DriverService
Computer: PLEXSERVER
Context Type: Driver
Context Name: Z-Wave : Z-Wave
Description:
An error occured while polling node 0.
TimeoutException: Failed to receive the Vizia RF '<X...' response within 30000 milliseconds.
System.TimeoutException: Failed to receive the Vizia RF '<X...' response within 30000 milliseconds.
   at BuiltInDrivers.ViziaRF.ViziaRF_RZC0P_Communication.getResponse(Char responseCodeCharacter, Int32 timeoutMilliseconds)
   at BuiltInDrivers.ViziaRF.ViziaRF_RZC0P_Communication.GetRFTransmissionResponse()
   at BuiltInDrivers.ViziaRF.ViziaRF_RZC0P_Communication.SendCommand(String command, Boolean getRFTransmissionResponse)
   at BuiltInDrivers.ViziaRF.ViziaRF_RZC0P_Communication.SendZWaveCommand(Int32[] nodeIDs, CommandClass commandClass, Byte[] parameters, Boolean sendSecure, Boolean waitForRFTransmissionResponse)
   at BuiltInDrivers.ViziaRF.ViziaRF_RZC0P_Communication.SendZWaveCommand(Int32[] nodeIDs, CommandClass commandClass, Byte[] parameters, Boolean waitForRFTransmissionResponse)
   at BuiltInDrivers.ZWave.ZWaveManager.RequestNodeLevel(Int32[] nodeIDs)
   at BuiltInDrivers.ZWave.ZWaveManager.PollNode(ZWaveNode node)
Any ideas?
macromark
Not using my Omni Pro anymore and am trying to get the Elve Zwave driver going....
Any ideas?
Well.... if you press your Omni Pro back into service, you can add a HomeTroller (or HS3 software) to it and use that for your Z-Wave network. We partnered with Leviton recently to provide Amason Alexa support to the Omni Pro using a HomeTroller. You can leverage that integration to handle your Z-Wave devices. Some information can be found here: http://communities.leviton.com/docs/DOC-5146
Here utilizing a Zee2 Homeseer 3 box running the OmniPro 2 plugin.
You can utilize OmniPro 2 Zone triggers to drive events on Homeseer 3 and do a custom built console touchscreen to access the panel.
The footprint being small fits just fine inside of the OmniPro 2 can.
