I would also use the RF Installer to "Set Routes" for the VRC0P with the compatible devices (aka Leviton switches and dimmers).
You should be able to unbrick it. I had a similar issue last year, but I followed the instructions in the pdf after switching serial cables and it worked. I think the issue is some usb to serial adapters do not work with their program (under windows 7?).
If I remember I used Windows 7 Pro, but had to dig out an old Digi adapter (USB to 8 serial ports). I had a cheap cable with a prolific chip from Newegg and it didn't work with Leviton's program!?! You also might try XP and see if that helps.
If you google, you'll find some people have issues with their update program, but everyone gets it working eventually.
"7.
If the update process is inteerrupted for eiither Flash filee;
a.
Cycle power to the Serial interfa ce
b.
Close and reopen t he Serial Boootloader
c.
Reopeen the Flash file
d.
Click oon “Start” and the update pprocess will reepeat"
"7.
a.
b.
c.
d.
