/archive/j/news/2010/2/P212S.jpg/archive/j/site/logos/elk.gifELK has announced the ELK-P212S, an ELK M1 compatible (via ths RS485 bus) supervised powersupply. Check the press release below for a detailed description and the technical specs.
The ELK-P212S is a Supervised Remote Power Supply / Battery Charger, providing 12 VDC output with up to 2 Amps of total current. It supervises the AC Power Input as well as the rechargeable Battery, and can report abnormal conditions back to an ELKM1 Control over the RS485 four (4) wire data bus. It also features relay outputs for AC and Low Battery to allow "stand-alone" operation with other Controls (Security, Access, CCTV products, etc.). Power from the P212S can be used to increase the capacity of a control, or to remotely power devices such as motion detectors, keypads, zone expanders, sirens, annunciators, etc.
Click here to view the article
