WGL Designs makes an X-10 driven relay output module named the Relay-8. This unit has eight single pole, double throw relays that can be controlled via conventional X-10 signals over a homes power line. This makes a very handy low voltage controller without having to use a module like a RLY-8 or SECU16 module with an Ocelot, or multiple X-10 universal modules. Plus, this unit can be conveniently located where the wiring controls are terminated (usually inside your garage), thus eliminating extra wiring that would normally have to be extended to the control system.
/archive/j/tutorials/2005/7/devices.jpg
WGL Design's Controllers and X-10 Universal Module
Click here to view the article
