WGL Designs has a new product that will let you switch eight single pole double throw relays using X-10 power line commands! This latest product is named the Relay 8. This unit can respond to X10 ON, OFF, ALL OFF and status request commands.
Here are additional specifications of the eight relays:
Click here to view the article
- Each of the 8 independent relays is equipped with a form C contact that is brought out to two plug-in, detachable terminal strips.
- 1A @ 24 VDC Resistive Contact Rating
- 1A @ 120 VAC Resistive Contact Rating
- Relay Contacts are designed for low current applications as well as power switching.
