Automating Liftmaster 1/2HP Garage Door Opener
felixrosbergen
So I'm starting to get motivated again to do some automatic and was looking at the garage door opener.
During construction i had pre-wired for a garage door sensor at the top of the door, so that should be taken care off pending purchase of a sensor.
I have a conduit nearby the control pushbutton and I've tested that if i create a short/connection between the 2 wires on the back of the pushbutton controller the door will open/close.
So as suggested in these forums I plan to run 2 wires connected to the 2 terminals through a relay at the ELK and control the door in this fashion.
The question is the wire gauge...will doubling up on some cat5e conductors do or do I need something more substantial? The cable used by the electrician to pre-wire for the door seems a bit thicker than cat5, more like cat3 or t-stat wire.
I don't know the voltage or the amperage, but this must be a very common door opener.
Any suggestions? I have cat5e in the house so would prefer to use that.
Doubling up should be fine. I have 22/2 to my GDO, and most Cat5 is 24 or 26 ga.
The thickness of the wire is usually caused by differences in the jacket or insulation around the 4-pairs.
Any other opinion? Not that i don't trust Sacedog..but it's nice to see consensus.. :)
Looks like I'll need to be getting the Elk Relay expansion..the relay board that connects to the control itself has a flat ribben cable right? How long is this cable? I need to figure out how to fit this into the can.
You don't 'have' to get an expansion board, though if you are going to use relays a lot for other items, it's probably a good idea to invest in one now.
For instance, the M1 has a relay on board and you can also just buy a single relay that can trigger off of the analog outputs.
Any other opinion?
I am using 24 gauge (a Cat 5 pair) for this as a matter of convenience. The LiftMaster manual recommends "bell wire" which is usually 18 or 20 gauge (right?). My thinking is, the circuit is closed for only one second at a time and anyway it's not really a current application. But this would not be the first time I don't know what I'm doing.
I have a 22/2 running to it since all my security wire is 22/. A Cat5 pair by itself (24g) should also be fine. If you have to run something from scratch and you have 22/2 that's what I would use.
