Autopatch 4YDM switching help
myyaz33
Any Autopatch experts on board? Having some trouble getting any output from it. I think I have a pretty good handle of how it works from the past posts here and on CQC forum. Basically a last ditch effort to find some help before calling AMX for paid support.
I have an autopatch unit working in my system. What kind of help do you need? I am no expert, but I can share what commands I use to control it.
I am not even trying the commands at this point. Just trying to get it to switch using the front panel. I think I have the input and output connected properly. Basically here is what i have done.
Striped down a Stereo->RCA cable on the RCA ends. This leaves the red(Right+) and white(Left+) and the common ground.
I attached the red wire to 4YDM Enclosure#2 Input#1 on the top terminal and the common ground in the middle terminal with a jumper between the middle and 3rd terminal. Same thing for the white wire in on Enclosure#2 Input#2.
For the outputs on the 4YDM Enclosure#2 Output#1 & Output#2 I did the same. The RCA outputs are going to the AMP.
I will take some pictures if that might help.
I just verified that I am an idiot. I was grabbing the wrong stereo cable and plugging into into the source. Apparently my work bench is cluttered with similar cables. Smooth move! Autopatch was doing what is was supposed to all along.
Glad to hear you got it working. Sometimes it is the silliest things! At least your unit is working fine.
