felixrosbergen
So if you don't have them 'in the field' then you still need them at the panel right? How do you wire them in at the panel? It seems messy to just have a splice with a resistor in it. Isn't there a board of some kind you can wire the zones through that don't have EOL in the field?
I woudl agree with you. If the wiring is in the wall somebody has to go through a hell of a lot of trouble to disable your system and then there's still PIR's to deal with once inside...hahaha after the PIR are somehow disabled there's my 20lbs crazy cat that will make a lot of noise...
How would you open up a wall from the outside anyway? Cut into the siding with powetools when you don't even know where the wriring is OR if the home owner has or has not used EOL's.....
I would much prefer to not have the EOL in the field if that prevents a splice (read 'potential trouble') in wall.
