IVB
>What is the type of wire from the Elk 28" cabinet to the mediacloset?
2 runs of 18/4 - one run to hook up to the data bus, one run to hook up the power.
>What about the type of wire from the Elk 28" to the keypad?
18/4
>Is the Elk 28" cabinet connected to a 110v outlet?
Not currently - i don't have enough sensors to warrant needing any more power than is provided by the 2nd 18/4 run in the first question.
>Also, the wires that you installed, are they inside a pvc pipe?
Not mine, no. My house is a 95 yr old craftsman, no conduit run anywhere. Plus it's a crapload of wire that i'm running [eventually 35-40 runs to that 2ndary cabinet]. I'm basically keeping all the wires running down the same joists, so I'll eventually have an arm-thick bundle of wires.
>And my latest story is this. I spoke to the coordinator yesterday and he told me that I can install myself the speaker wires. However, I want to mimic something that is similar to model houses. You can hear the same music to wherever you go but of course, there should be a way to only let the music sound in specific rooms. So guys, what should I do?
Ah, that's my step 9 here. I'm running speaker wire all over the dang house now. I'm using CQC to manage my audio equipment, and I've got it setup to be able to use a variety of devices to handle whole-house audio.
Here's the "extreme" pic that I drew up and posted on the CQC forum that shows the wiring runs if you want to distribute HDTV, SDTV, and audio. None of the particular equipment is mandated, I picked model #s more as a example of the equipment that you'd want.
You obviously don't need to go this far into it, but let's start with the max and work backwards rather than from scratch and work forward. Also, I'd encourage you to read through the CQC "installation and configuration" forum as the community created several custom-fit drawings for folks interested in managing whole-house audio & video, and we tailored it to their particular equipment/rooms/needs. It's impossible to design this for you without understanding what you want, and reading through those posts may help you decide what you want.
Read through this thread if you want to see all the comments people made about this horrifically ugly drawing.
18/4
