nicholass817
Hello,
I am currently in the process of buying a semi-custom home in a master-planned community. I have somehow convinced my wife to let me install an solid infrastructure for a home automation system. Because of this i have asked the builder to pre-wire and install a few items, and I wanted to run it by y'all to see if there is anything I should add/modify/omit.
The basic systems are going to be:
I am having the builder install:
Any and all advice is greatly appreciate.
Thanks!
- Elk M1 and all the necessary components
- ISY 994i Smart Meter (though I have been looking into RadioRA 2...intriguing)
- Insteon dimmers/switches/etc.
- Somfy 12v RTS tilt motors (24 total) and Somfy Glydea RTS curtain motors/tracks (5 total)...
- Pre-wire all doors and windows with security contacts
- Pre-wire motion/occupancy sensors in every room and closet
- 3 keypad locations (MBR, Front entry, and rear entry) with cat5e/6
- 28" security enclosure w/ dedicated 15a circuit
- 16/2 stranded wire to every window head for tilt motors - home run to an empty area in my "brain" closet where I can install a surface mounted enclosure for the low voltage transformer...need to run power to this but am unsure of the required circuit amperage for up to 24 12v tilt motors.
- 5 outlets at the locations that we want powered curtains. Big question here... do each of these need to have a dedicated circuit?
- 1" flexible conduit (smurf tube) to each of the TV locations (tv will be through a ceton windows 8 based server and xbox 360s, movies are through a mac/itunes/apple tv setup)
- outlet to dedicated circuit for isy/powerlinc
- additional outlet for wall mounted rack with servers/switch/etc.
Thanks!
