I'm looking at installing an Elk M1G system in my home.  I haven't done this before, so I'm not sure what a well known brand would be for a wired PIR that meets the numbered criteria below.
The plan is to install PIR's in several rooms to control a Vizia RF+ lighting system. Since this is the PIRs sole purpose, I'm looking for a PIR that:
1. will instantly change state (i.e. no time out period between triggers like most wireless solutions do; this is a must for occupancy sensors)
2. has a low current draw (I'm assuming all wired PIR's meet this requirement) as I want to run Cat6 23 AWG cable; such cable should be able to withstand ~700mA for each run; I'm wiring each motion sensor to it's own zone so that room by room occupancy can easily be tracked by Premise
3. is pet immune, yet sensitive enough to trigger the instant I walk into a room
4. is known to have very few or no false detections.
Any suggestions are appreciated!
		 I plan to run extra conduits into the attack so that I can add more later though.
