Monk and wuench (and others using the CM-9), I have a couple of questions about how you use the CM-9...and hope this thread is not too old to use.
It looks to me like you would need the realy version (CM-9 R) to work with Elk, and that the relay would signal Elk, and then Elk would control the lights...is that right?  I was thinking of doing that and it looks like I could do it without the Sensorswitch powerpak as long as I could get 12V to the sensor and did not want the sensor to control a line load (just Elk via relay).  I couldn't figure out how you would use the Elk without the relay version since then the sensor only controls the line load, but wanted to see if I was missing something...
Thanks!
