CT Droid
CT Bot
I have installed one of these cameras and will most probably get a couple more - the first one is currently being used as a front-door cam. They are pretty inexpensive as far as weather-rated TCP/IP cams go.
The built-in motion detect works very well. Note that you may see mention of POE - this camera uses its own proprietary "injector box" for power. It cannot be used with standard POE hubs or switches. Still - the ease of a single Cat 5 wire and 175.00 price tag makes it worth while.
Tivo Update - took the new HD Tivo out of the box finally and hooked it up to an existing analog tv. Still need to pick out a new flat screen.
Home automation update - I still have a ton of uninstalled hardware laying around.... the aux power supply is probably next.
