I calculated all my loads on the panel based worst case/ alarm current, from the specs on the cut sheets of each device. The only items I had trouble calculating are the water leak detectors GRI 2600 and 2800s. I did a test and could see little to know additional load when in alarm mode. But those are not on the control; they are on the P212s.
Changing the base was the next thing to try, though i don't see how the base would go bad. it is pretty simple.
Now something that i just noticed, another motion on first floor is having a similar problem with the LED. Again, I have not touched this unit since i installed it and it has been working fine. LED does not come on, but the motions are working and reporting back to control when motion is detected.
On the kitchen motion, i tried switching the LED of and on thinking it could be issue with switch not contacting properly, but LED is still not working. If I have time, I can try calling Bosch.
