Since Brultech is closed for the weekend...
I want to have one ECM-1240 next to my load center in my shop which is about 150' from my home. My shop load center also feeds my home's subpanel. I want one or two ECM-1240's in my home next to it's subpanel.
Questions...
1. Anyone know what the wireless range is for the ECM-1240? The Brultech website says that for the ECM-1220, it is 133/400 indoors/outdoors. Is it the same for the ECM-1240? Is it the same for the EtherBee?
2. If I have range problems with the ECM-1240 in my shop, can I connect a 2nd EtherBee to the LAN switch in my shop (resulting in one EtherBee in my shop and one in my home, all on the same LAN) and will the data look the same at the PC as if all ECM-1240's were talking to the same EtherBee?
3. Again, if I have range problems, I can connect the shop ECM-1240 to a Ethernet switch on my LAN via the EtherPort device, but how will the data from the multiple ECM-1240's look to the PC?
4. Anyone know if Brultech will sell an ECM-1240 without any split CT's? I only need one pair, so it seems like a waste of money to get two additional pair.
5. From the Brultech online store...what is the reasoning behind the ECM-1240 "Package B+"? It has "with wireless radio installed" (which I assume is the XBee radio), and the EtherPort adapter. Is that just for additional flexibility? Is there any reason for having both communications methods running at the same time?
Ira
Questions...
Ira
