I have an Altronix eFlow 102N16 power supply that is in a wall-mount enclosure. I need to get the output wires (12vdc) to a nearby (five feet or so) Elk recessed enclosure. All of the knockouts in the power supply box are on the tops and sides, none in the back of the box.
Any good suggestions (pictures) on how to cleanly/neatly get the wires from the side/top of the box into the wall behind it? The wall is covered with drywall.
I'm pretty sure the answer to this follow on question will be "no", but is it okay (whatever that implies) to move the internals from the Altronix box to an Elk box of similar size that can be recessed mounted? It looks like all Altronix PS's are in wall-mount boxes. Maybe because they are not typically used in residential locations, or maybe heat buildup if recessed in a wall is a problem?
Ira
Ira
