Hi, I'm considering putting an NX-8E into property I will be renting. The reason for the NX-8E choice is because it already has a CQC driver and I'm looking to use that to be able to trigger CQC events later. Since it is a rental, pretty much everything outside the closet will need to be wireless. The property is located on the top floor so the only access is via the front door and rear exterior doors and the living room balcony although I may add motion sensors for automation purposes too.
I like the LCD keypad option, and I see there is a version with a wireless receiver in it or should I go with a separate wireless board? All advice welcome
