Still trying to find the easiest way to distribute power from my additional power supply for Elk M1G
Can I use my secondary source (power supply/battery charger (ELK P624) and battery and 16.5 volt transformer) to feed power for my additional Input and Output expander, just running 12v + and neg to the expanders and then using cat 5 cable (without the wires from cat 5 to the power terminals on the expanders) to connect the expanders to the Database Hub?
Also, I have a surge supressor for power and tele line (ELK 950) on the original power supply to the ELK. Should I get another one for my second power supply, or is this necessary as the doc for the ELKP624 says it has built in surge suppression?
David
David
