I don't have the M1ZTSR temperature probe, but I am considering adding one. Is there a way to have the M1G say the temperature? As in "The Time Is [Insert Time] The Temperature Is [Insert WHAT]" Can this be done?
It is "THEN ANNOUNCE TEMPERATURE READING OF [zone]" which you get from the Speak command, scroll to bottom of the list for installed temperature sensors.
I have observed a bug in the announcement. When the temperature is 100 degrees, the Elk Girl says "Hundred degrees" (omitting "One").
Thanks for the help! I didn't have any temperature zones configured so it wasn't on my speaking list. Once I set up a zone as type 33, there was temperature, just like you said.
My keypad has a temperature sensor in it. Can this sensor temperature be announced by the system (via rules)? If so how do I activate it as a zone so that I can set it up and speak it from a rule?
Thanks, John
