This is now become a bit of a DIY modification of a Speco IP67 HT 650 Dome analog camera to one with a Grandstream IP HD board combo mini stacked IP / Camera board replacing the Speco 4mm lens camera board.
Will take pics of the the Speco take apart, modification and installation of the Grandstream camera board.
Took apart the Speco HT 650 last night. (another one still in the box) The main camera board is a 38mm square board. I could probably leave the board in place and connect it to the Grandstream IP board. (they are all stock connections with the same pinouts) - new camera board though uses a small ZIF cable between boards.
That said the Grandstream based OS HD board is double stacked with the camera board at 38mm and the IP board at 51mm wide. (assumption - a little bit of a plastic mod but easy fit). Description calls it a indoor camera.
The lens that comes with it a 3.6mm lens which will do just fine. The two boards/UV shutter look identical to the Grandstream GXV3672HD.
The four pin plug on the IP HD camera board for the IR "appears" to be the same as the one on the Speco camera board and most likely I will be able to utilize same small plugs and cables. (experiment will be using both analog and HD video from said board / camera).
Changing the power source though from current 12VDC (which does other stuff today in the mailbox) to a 48V POE connection with a voltage splitter providing another 12VDC source (just for the camera). (using an unused Cat5e connection run a few years back).
Attached is a picture of the Speco dome camera disassembled. Replacing the single camera board with a "double" stacked cameraboard and IP board. Cabling out will be similiar with the network interface as the add. (12VDC, Analog video and IP port).
Using a 3.6mm camera board (38mm X38mm) and over it will be the IP board (51mm wide).
Specifications to camera board are as follows:
- 1/3" 1.2MP CMOS Sensor (Aptina MT9M034)
- TI DaVinci DM365 DPS
- Resolution:1280 x
960@25 fps/1280 x
720@30fps
- Built-in Dual Filter Switch IR-Cut System
- Built-in WEB SERVER, Support IE browsing and parameter Settings
- Free Video Surveillance System (For PC)
- H.264 video encoding, h264 format (Can be converted to AVI)
- Dual video stream transmission
- Support 554 RTSP
- Support the motion detection (smtp with jpg)
- DC 12V Power input
- Support Blue Iris video software (Brand: Grandstream)
- Support Synology NAS surveillance (Brand: Grandstream)
