PaulD
I have read other threads where people have looked at options to get rid of wall warts as well as some thoughs on use of a CCTV power supply for a generic power supply with multiple outlets.  However, I never did see anyone comment that they actually used a CCTV power supply or any other similar source with multiple outputs along with any pro/con comments.  To do this, I have been looking at several different models and options.  My intent is to get a unit that ....
a) is UL listed
 has 16-18 outlets (or 2 each of the 8-9 outlet models)
c) has master fuse and also provides at least 1000ma PTC protection on each outlet (no fuses). If a device requires more than 1000ma, I will use multiple outlets in parallel as required.
d) has minimum of 10A total capacity. More is desired but the higher amp units tend to use a power supply with a fan to make noise. May decide to use multiple smaller units to get a higher total amp capability to avoid fans.
e) is reasonably priced. The units I have seen from typical HA sources (HAI, Leviton, etc) seem to be too high priced for the limited capability they offer. I have not see any capability they offer that I need that is not provided in a CCTV power supply.
I am looking for any cautions or issues I need to be alert for before I pull the trigger and install a CCTV power supply as my single 12VDC power source to support my 12VDC requirements in in HA closet. Also interested in any suggestions on specific power supplies that anyone has found to be especially good.
			a) is UL listed
 has 16-18 outlets (or 2 each of the 8-9 outlet models)c) has master fuse and also provides at least 1000ma PTC protection on each outlet (no fuses). If a device requires more than 1000ma, I will use multiple outlets in parallel as required.
