I've noticed when changing the temp multiple degrees Haiku will not always reflect the desired temp. For example if it is set at 66 and I hit up to 68 it might go to 67. What I think happens is it sends the first temp change immediately and the OmniPro sends a status update before the second temp change is sent reverting my change. Would it be possible to add a delay of a second before sending the command? This would emulate the Omnistat where you can change the temp up/down and wait a second before it commits.
