mdesmarais
(all measurements I am talking about are at the lock/solenoid) If you have access to an oscilloscope you could look at the wave form of the 12v... if not, if you have a multimeter with a frequency counter function that could be interesting. If you have just a regular meter, check the DC voltage.
It should work fine installed at either end of the cable. It sounds like the PWM is at an audible frequency- if you found one that operated at a higher frequency, you should not be able to hear it. Maybe the unit that DEL mentioned above.. I can't find anything specific on the 7200 as to exactly what it is, so somewhat of a guessing game.
