I got the Hobby boards master hub and just one sensor to check out one wire network before I go and add more sensors. I have the temp, humidity and solar sensor from hobby boards.
I wish someone would do a simple how to hook this stuff up and set it up in say Weather display. This would be a huge help to people just trying to figure this out from scratch. It's very confusing and I am not getting good results so far.
Without any guide on the hobby board web site I have no idea if I am doing any of this correctly and it's very frustrating.
Here's where I am at.
I downloaded the one wire drivers at maxim.
I am viewing the one wire network using the java one wire viewer.
The viewer shows 3 couplers, a DS18S20 and a smart battery monitor?
What is a battery monitor?
I see tabs for temp, humidity, AD, time whatever.
Temp reads fine and so does humidity.
Where is the solar reading?
This all took several hours last night to get this far without any sort of guide.
Sifting through tons of post here and only getting bits and pieces here and there. Seems like a setup guide could have given me the information in less than 10 minutes.
Am I crazy or does it seem like a good idea for a company selling hardware to show their customers how to set it up. I don't just mean how to plug it all together.
Sorry for the rant, you have to realize how confusing this all is when you are starting from scratch.
I haven't even gotten to how confusing weather station is and how to set up a one wire station. I finally got weather station to read the one wire network. Then the next time I start up weather station, it's not reading it. I have to go play around with the one wire setups every time to get it to read temp and humidity.
Sometimes it finds the one wire sensors and then the next time it doesn't.
The hub is lit up properly and the java viewer reads everything but weather station will not start reading it untill I mess with wind sensor settings, which I don't even have.
Is there a better/simpler piece of weather software out there?
Do I have the drivers for the Hobby boards stuff set up properly?
Why the heck is something that is supposed to be simple like a one wire, not simple?
