Black Magic
How can I connect the ELK-SP40 to Output 2? The output is supervised, so I'll need to use a 2.2k resistor. Should I put the resistor in-line or parallel to the speaker connects? Putting it in-line seems like I would blow the resistor. Putting it in parallel looks like the resistor wouldn't reall work. I thought you could just hook up a speaker to the siren driver.
How do I connect the ELK-RJSET to the M1 Gold? The RJ31X has spade terminals that don't connect to the telco block on the M1 Gold.
