Connecting Grafik eye to electrical outlet
gasbie
Can someone please give me a diagram or description of how to connect my grafik eye (3506) to a power outlet that will be used for rope lighting. Thanks
Not sure I understand the question. . . so correct me if my answer is not what you were looking for.
The Grafik Eye should be connected in a junction box, like a regular 120V light switch. Black to Black, White to White, GND to GND. The rope lighting would be hardwired to the Grafik Eye in a similar fashion, Black to Zone X output, Neutral to Neutral.
Dimming a standard convenience outlet is against NEC code and should not be done. . .although I see people do it all the time. If you were to put a receptacle on a dimming circuit, Lutron makes a special receptacle and mating plug exactly for this purpose.
Craig
Craig
where can I get this special receptacle from AND what is the name of the receptacle?
Check out the link below for part numbers. . .
http://files.lutron.com/hwi/TRG/366-963h_components_dimming_receptacles.pdf
