Dean Roddey
A very late beta of CQC 1.4 is available if anyone wants to play with it. By very late I mean it's basically about ready to ship so it's only a beta in name. It's really very solid and has been through a number of internal betas and within the existing user community.
The major new goodies in this release are:
http://www.charmedquark.com/Web2/WebTest/
There is a new 'Quick Tutorial' now, which is online instead of being in a separate Word document. It's the fastest way to evaluate CQC. Use the Learn tab, and then select the Quick Tutorial link and you can step through it. It will take you through a hands on installation and configuration of CQC. It will only be able to skim the surface in that short a time, but it will give you a good feel for what CQC is and does, what tools it provides, and so forth.
Feel free to give it a whirl. It's available for 30 days unencumbered, so you can play with it without any limitations . The new media stuff and the powerful new command system really crank CQC up to the next level. It now probably has the most powerful back end out there in the software-based world. The front end has now pulled even with the competition in terms of power and flexibility. And now we offer media management in the same package.
As far as the outlook for 1.5, the currently planned bit ticket items are:
- Media Management. The biggest ticket item in this release is CQC's first steps into the media management world. Our driver architecture has been extended to support 'media drivers'. This allows CQC to provide browsing of media repositories and control of media renderers, and to coordinate them into a coherent media system.
- Graphical Interface Features. CQC's user interface designer/viewer system has been extensively improved in this release. Interface widgets were added to support the new media management features, to allow you to view cover art, to browse media categories and cover art. The 'action system' was extended to include the interface widgets themselves, allowing you to create very dynamic interfaces without any programming. The new toolbar widget is a very convenient way to provide access to more buttons than you have physical space for. And a new simple animation widget allows you to easily represent the active states of devices under control.
- Elk M1 Support. A new driver is available for the Elk M1 and M1 Gold automation panels. It supports both the serial and Ethernet based connections. The M1 is a very popular automation panel that is very reasonably priced.
- Escient Fireball Support. The first media repository device supported in our new media architecture is the Escient Fireball, which is a single zone, media repository and renderer for CDs and DVDs. You can browse the Escient cover art database and control it during playback.
- J.River Disk Repository Support. J.River Media Center 11's disk based media repository is now supported as a CQC media repository, so you can browse the repository via category and cover art and invoke a renderer to play selected media.
- Zoom Player Support. Zoom Player is now supported as a media renderer, and is a very powerful combination with a file-based media repository like J.River above, with CQC providing the coordination.
- Undo in Interface Designer. The user interface designer tool now supports Undo, which allows you to safely experiment or to recover from accidental changes.
- Z-Wave Driver Improvements. The Z-Wave driver was vastly improved in this release, and now is very quick and very reliable. Z-Wave automation via CQC now shows what Z-Wave is capable of.
- JPEG Support. You can now import JPEG images into CQC for use in interfaces, in addition to the already supported PNG and bitmap formats.
- Our own media ripping and meta data retrieval utiltiy. So we won't depend on any third party tools to let you create your hard drive based media respository.
- A streaming server to support SqueezeBox, Exstreamer and other distributed music clients. So we'll be able to provide zoned music streaming from our own repository.
- And we will plug a final hole in our back end capabilties by implementing an event system (i.e. if this happens, make that happen.) For us, this has to be a network-wide scheme, so we've had to think it out carefully and are ready to get this taken care of now. Since we will likely base it on the xAP scheme, it will only be a reasonably short jump from there to supporting xAP/xPL.
- The .Net Viewer will become a full production product by the 1.5 time frame, actually before then, so we'll be alble to fully support small handheld devices. It is also available in a fairly early beta form now if you want to play with it.
- And we'll be delivering our own hardware based controller configuration in the 1.5 time frame.
