I just now started using Insteon and the Insteon driver that's posted here. Has anyone already installed and automated a three-way light circuit using this driver and SwitchLinc dimmers? Any advice on how to proceed?
I replaced the two switches in a three-way light circuit with two SwitchLinc dimmers and cross-linked the two dimmers as suggested by the guide for the SwitchLinc dimmers. They operate well on their own, with both switches' LEDs staying in sync. Now I want to make Premise aware of them and add some more interesting automation.
The SwitchLinc dimmers appear under the Insteon Root under the Devices as expected, but the Premise driver apparently isn't aware of the fact that the dimmers are cross linked (not surprising, when you think about it). As a result, when I push a button on the 1st physical switch, the state of the 2nd switch device object doesn't change in Premise (although the LEDs on the physical switchese are updated, since the two physical switches are cross linked). It's not obvious how to best model this arrangement within Premise such that:
Frank
- The state of the light object in the home model is affected by button presses at either physical switch.
- Any changes in the state of the light object in the home model results in the proper LED state on both physical switches.
Frank
