Hi everyone,
I want to use a DS2413 (max voltage on PIO is 28V, max current on PIO is 20 mA) to drive a relay with the following controls specs:
Control Voltage:3-32VDC Control Current
C 6-25mA
Seeing this, it would seem that anywhere between 6 mA and 20 mA would be acceptable both by the DS2413 and the relay.
I dont have any 5V sources handy, but I do have a 9V battery close by to do some testing. I was thinking about using the "DS2405 as a led driver" sketch found here
, replacing the LED by the relay's control and the resistor by 1 kilohohm resistor, which would give me 9 mA (9V / 1000 ohm)
Would that work without breaking anything?
Also, this relay is specified for 240V-480V AC ... do you think it would accept 110V AC too?
