Desert_AIP
Looking for advice on door contacts.
I searched and looked through several threads, but I don't see anything speaking to the reliability of particular switches.
I'm not sure if it is the contact I am using, the way I installed them, or some other factor, but I have had 3 failures in 6 months.
I installed the GE 3008W roller contacts on the hinge side (with EOL) of all my exterior doors.
I've had two fail closed (i.e. open the door and the contact does not open) and one fail open (i.e. close the door and the zone still reports open).
I double checked the wiring with a meter and the failure is at the switch itself.
These are placed on the hinge side jambs just below the bottom hinge, about 3-4" off the ground and sealed with silicone.
I've tried with and without the spacer. Doesn't seem to make much difference when the switch works and no difference when it fails.
I don't see any dirt, paint, ice, etc. in the roller or cavity. The spring action of the roller still works.
So I suspect the GE switches are just not reliable.
All my other contacts are GRI. I was looking at the GRI DS and RB series. The DS spec sheet has a note:
"Important Note: GRI’s improved DS and RB Series of products are not recommended for the bottom or side track of
windows and doors."
So now I am not sure whether they are suitable or not. I can understand why I wouldn't want them on the bottom, but the side comment confuses me.
Any advice is greatly appreciated.
Thanks.
windows and doors."
Thanks.
