Doorbell and Camera Wiring
nspinelli
Hello All -
I just wanted to get some feedback on what type of wire I should run to power my doorbell and outdoor cameras? I am down to the studs and getting ready to start running all of my ethernet and security wire for Omni Pro II and HIFI2. I just wanted to get some ideas for how to run the doorbell and front door security camera?
Thanks in advance,
Nick
Are you installing some form of Smart Doorbell or Intercom system, or a standard doorbell? Does the doorbell have an integrated camera or is the camera separate?
If you have products (model numbers) already, list them here.
For the doorbell i was thinking about using Spore True Non-Illuminated Doorbell Button; Brushed Aluminum. I am not sure about what cameras I am going to use. Do you have any recomendations? I wanted the doorbell to just play a file over the HIFI2 system in the house once pressed. I read a forum post here about using the ELK960. I just need to know what type of wiring I should run to the doorbell and camera locations.
For camera location:
At least an 18/2 or more conductors, parallel; mid-cap; solid, non-twist would be a start. Category cabling would probably also be prudent.
For pushbutton, I'd pull only an 18/2 back to the central location. The remaining can be done via other means.
