I have quite a few HAI 35A00-1 dimmer switches that perform very well except for one minor problem. I've programmed the double tap bottom rocker action to fade at a much longer rate than the defaut fade rate. The switches when double tapped all fade at the default rate and will not honor the rate entered via Upstart which happens to be 1 minute. I've tried this on several switches and I've tried to double tap very fast, slow and every combination I can think of and they all fade at the default rate regardless. What am I missing?
