Hi guys,
So over the last week, I was bitten by the Home Automation bug. My initial plan is to start out with my living room and kitchen lights, plus powered Hunter Douglas shade.
I've decided on UPB because it seems the most DIY-friendly, the switches have a true rocker up/down action, and there are dry c ontact output modules available (to control the shade)
What I'm curious about is just how much "brains" are available in each switch. I realize the switches can execute an action based on a button tap or hold and they can send an action based on a button tap or hold.
What I want the switches to do, though, is this:
1) Send a link if a certain condition is true at the switch
I.E. - If switch A is turned off (regardless if it was tapped off, dimmed off, or received a signal to turn off), send a "turn off" command to Switch B.
2) Execute several commands in a SEQUENCE
Scenes and variable dimming rates are nice. What I'd like to do, though, is turn the lights on and off in a specific sequence, say illuminating areas in an open floor plan house one at a time. For example, I'd like for one Keypad button to: Snap turn off lights at Switch A and dim lights at Switch B over 3 seconds. Once Switch B is done, dim lights at switch C over 3 seconds. Once switch C is done, dim lights at switch D over 3 seconds. Pushing the button again should reverse the process - i.e. gradually bring up D, then C, then B, then snap on A.
Can UPB switches be programmed to do either of those tasks? If not, what's the easiest/most cost efficient way to do this, ideally short of an always-on computer with full fledged home automation software?
