Over the years here have mentioned that I use PCS, HAI and SA switches in UPB mode connected to my OmniPro 2 panel.
The above has worked fine for me. I have multiple UPB PIMs in place outside of the HAI connected UPB PIMs and see UPB HAI switch status just fine here.
I decided this week to tinker a bit with HLC mode using only SA US1-40's. (giving up a bit on the US2-40's for a time).
I have followed the old HAI KB documention posted and what is posted here relating to said endeavor.
Been using Upstart to configure the US1-40 switches using the matrix spreadsheet.
Using OP2 connected HAILogger, Homeseer Software plugin, Omnitouch 5.7e and Snaplink to watch status.
Side loading UPB software Upstart and HS3 Plugin seeing switch status change just fine (expected).
I have an HAI UPB repeater, SA and PCS UPB phase coupler attached to my fuse panel each device has a separate breakers.
I am using a UPB plugin software here to see UPB switch and UPB link changes as I am supposing that HLC status is using the UPB link status for changes to the switch.
When I test one switch manually turning it on or off I do not see the status changing in the above applications and wondering what I am doing wrong.
Here is the configuration of one US1-40 test switch. (doing screen shots here of switch / link configuration as shown in Upstart and screen shots of PCA HLC switch configuration).
Toggled switch on with a double tap and watching links 242/241 and see this:
Disabled HAI repeater via breaker and tested communications to US1-40 switch.
Good communications
Looked at links 242/241 and now see only link 241 status snap on or snap off. I do not see any status changing for link 242. Omnitouch 5.7e control / hallway switch view shows no status changes.
(IE: have to redo my pictures to fit this stuff here).
Good communications
