Hi Jayson,
Uninstalled and installed application and it no works. There are still some issues
Lighting
The only issue now is the dimmer slider. It works some times but is very intermittent. It won't work at all mostimes, when you get it to work you might be able to slide a change once then it sticks and won't slide. The changing state on page slides now has been fixed.
Zones
Jayson zones remain very confusing! Did you have a look at the color code in ELKRM? I am now seeing your clear "colour" however it is not reflective of what the ELKRM (M1) status is. I am seeing where say a zone is violated the EKeypad is reporting clear or unknown state. I am seeing M1 violated ELKRM red X and you are reporting green. So the status is not reflective of the actual and combined with your colour convention it is very confusing and indeed not correct.
Red = Violated irrespective of whether the M1 is armed or not
Green = Non-violated irrespective of whether the M1 is armed or not
Yellow = zone bypassed irrespective of whether the M1 is armed or not
Clear = Say when EOL state detected irrespective of whether the M1 is armed or not . M1 in theory shouldn't have an unknown state
I think most would agree that having the above colour code convention would for us M1/ELKRM user makes perfect sense.
Outputs
These now are are working fine
Keypad
The dots now follow the page selected.
General comments and suggestions
The zone colour code convention I believe needs to be changed.
Could you have a connected status flag say on the top red or green dot confirming if the interface is connected to the the M1. If either the WiFi connection drops or the connection to the M1 drops then the status changes. That way you know if you are connected to the panel. Also when there is a disconnection Ekeypad doesn't seem to want to reconnect you have to close the application then open it again. It would be nice if it drops to retry and the suggest connection status reflect that it is trying to connect and confirm if successful.
Jayson some good progress in 1.0.5 not 100% there yet but getting there!
Regards,
Fleetz
Lighting
Zones
Outputs
Keypad
Regards,
Fleetz
