I'm starting work on updating my place.... it's an old 2 story 2 family house. We live on the 2nd floor, my grandfather lives on the first. We have a full basement and a unfinished attic space. I plan on adding a storage room in the basement which will have a wiring closest which will contain the starting point for the whole house networking, tv and telephone. I currently have a 15x3.5" wall cavity that goes from the basements all the way to the attic. Only thing currently in it is a single hot water pipe that supplies our kitchen. I need to get the wiring from the basement to the attic and then drop them back down the center walls into each room.
I am hoping I can use this cavity to make all of my bundled wire (2 RG6 & 2 cat5e) drops. Right now there will be 4 drops with one more to be added at a later date when we remodel our kitchen. I was also hoping I could manage to run new electric wires in the same cavity to supply each of the rooms as the wiring needs updated. A lot of the rooms are on several circuits and curcuits span multiple rooms... it's a mess...
Would running the bundled wire and elec. wires in the same cavity cause an issue? I was planning on attaching the elec. wires to the left stud and keeping the bundled wire on the right stud. Should I put something between the two groups of wires or should they be far enough apart that they won't interfere with each other? If I should put something in there, what would be the recommendations? Right now the cavity is open on both my grandfather's floor and our as I've been cleaning up the existing wiring that's in there. Was some old telephone and OTA antenna controller wires. I plan to start running the bundled wire later this week and the elec. would start sometime in Jan or Feb. I plan to close up the cavity on both floors prior to the wiring being completed but will have two 14x14 access points, one on each floor.
Thanks in advance for any guidance.
