michelkenny
I'm strongly considering adding an electric door strike to the door leading to my attached garage, controlled with a prox card reader. My door currently has a deadbolt and a handle with no lock. I already know that I need to replace the handle with something that locks. I'm looking at a storeroom configuration, where the outside is always locked (unlocked with a key) and the inside always opens freely.
I've been wondering though, by removing the use of the deadbolt, doesn't that make the door easier to compromise by using things like credit cards, coat hangers, etc. that are meant to slip in and manually push the latch back into the door allowing it to open?
I understand that some latches have a 2nd smaller latch, called a dead latch, that when depressed will prevent the main latch from being manually pushed in. In this case, I would have to align the electric door strike perfectly in order to ensure that the dead latch is depressed when the door is closed. By reading some threads here on CT, I see that some electric door strike owners might not be using this dead latch. What are your thoughts on this? Is anyone worried about lessening the security of the door by removing the use of a deadbolt?
