I have an omnipro 2 with lots of sensors attached. As each of these sensors require their own +ve and GND supplies, what I did is run a couple of wires from the omnipro 12v and ground output to a terminal block which then supplies all the attached sensors. See the picture; the top of each block shows the sensors coming in while the bottom of the block bridges the supply.
However, I am seeing some funny behaviour which is that I could be working on one sensor and it could trigger a sensor in an entirely different zone.
For example, yesterday, I ran power to an Arduino from the above terminal block, and when I also plugged in a USB plug into the Arduino, it blew the Arduino, and at the same time, triggered several Omnipro zones, stopped a console working and triggered both the internal and external sirens.
I have an idea that the problem may be due to floating grounds which are different between the sensors, and I have many +12v and GND connections going to the same place in the terminal block. The case itself is totally earthed.
So here are my questions:
1. does this seem like a likely cause?
2. Is it bad practice to use the same supply connection for multiple +12v and GND
3. Is there a solution that doesn't involve a terminal block that is 50 wide and takes up a huge amount of space...
