felixrosbergen
And beelzeron, if i recall you confirmed that if you turn on multiple lights from CQC the commands are executed at a speed that approaches instantaneous to the human eye right? No 1 sec delays between commands like the darn ELK.
It woudl be nice if the CQC driver could 'trigger' the scene defined within the ALC controller like the scene switches do. This woudl save quite a lot of potential programming.
On the other hand the method in which you have to programm the scene switches is rather crazy in my opinion. If you had 12 scene switch on which you want button 4 to be 'All Off' for all of them and you have 49 dimmer and you just added dimmer #50 you woudl wan that dimmer to be part of the All Off. The way i understand you have to reprogram each button on each scene switch where you want this new dimmer to be included. Reprogramming a scene means redoing it from scatch (there is no 'adding' function)...so thats 12 laps through the whole freaking house pressing 50 dimmer buttons (600 presses in all).
I'm more tempted to use the scene switches as 'dumb' input buttons to CQC and programm the scene with CQC actions. There you can create each scene once and edit it where needed.
