I just bought some UPB modules to start my upgrade from x-10. To get a feel for how well they work I setup a test environment with Elk/CQC/eKeypad. I setup a network using UpStart and the signal is excellent and there is virtually no noise. From Upstart everything works great and exactly as expected.
Next I added a serial port expander to the Elk and configured it for UPB per the instructions. I made sure the network number was the same as the network I setup earlier. Regardless of where I attempt to actuate the modules (CQC or ekeypad plus) I get very strange results. Turning a lamp on or off is intermittent. Sometimes the module turns on or off as expected and other times it will not respond at all. Since this sounds like a phase coupling issue I made sure the module and the PIM were on the same circuit and still have the same problem. I'll add a phase coupler pretty quickly but with both items plugged in the same outlet I'd expect it to work every time. I am using a different PIM for the the Upstart and the Elk but only one is on the network at a time.
Is there some trick to getting UPB to work reliably with the Elk?
Dale
Dale
