Elk ELK-M1XRF2G compatible sensors and Door Bell Button?
jwilson56
I am looking for new things to add to my HA setup so was wondering what type of Elk ELK-M1XRF2G compatible sensors people are using and for what functions.
Lets hear some of your ideas and uses.
Also is there a Wireless Doorbell button that is compatible with the ELK-M1XRF2G? My current door bell stopped working so it would be great if I could replace it with one that can be tied into the Elk.
Do you have an existing doorbell? If so, put a wireless door sensor (reed switch) in your doorbell chime housing against the solenoid. You might have to play with the positioning, but the magnetic field generated when the button is pressed should trip it.
Also keep in mind that the ELK ignores repeated signals for 8 seconds. So if someone pressed the doorbell button multiple times, it would only register once every 8 seconds.
